Crate amps GT3500H Shockwave pot help
I’m in need of help finding potentiometers that are appropriate for each function.
P1) overdrive gain
P2) solo gain
P3) solo shape
P4) distortion low
P5) distortion high
P6) overdrive level
P7) clean level
P8) clean low
P9) clean mid
P10)clean high
P11) reverb
P12)solo level
P13) distortion mid
One pot was already swapped and probably not the correct resistance either but these are the original pots that were removed:
A’s)50K, 50K, 10k, 10K
B’s)50k, 50k, 10k, 10k, 10k
C100k
also 2 don’t have printed values anymore I read anywhere from 1.95k-2.8k for the highs and low values 14-38  ohms
the second pot has been frustrating:
14m, 5m, and 10k for the high readings and 300k, 2.5m, and 25k as the low readings.
that leaves one more mystery pot that was replaced to figure out.  Any help would be appreciated.
I’m not sure if I wrote down all the values when I removed them.  I wrote on the board values that match up to everything correctly with the 2 non legible pots as A2k’s. Which just leaves the mystery one.  I only think I could’ve written them during removing them because I don’t have a value for the pot that was replaced prior to me touching it.  Sorry for too many details I figure it’s better listed now rather than playing tag.
