How to adjust DVD/CD LASER
As you look at the two pots head on, is the right side for DVD and left for CD?
To increase laser strength/brightness, do you turn clockwise or counter clockwise?
I would like to know if the two pots/settings are supposed to be tuned together?
Thank you
Mr._V.
Mr._V. picture
One is DVD, the other is CD. The two are independent of each other. So there is also the case where you can't set up the CD because it's tired, but the DVD will work for years.
First measure the resistance of both in their current state so you can set them back there. Then start adjusting one of them, in this case by say a larger adjustment, then insert a CD and a DVD. Here you'll see which one you can't read now. This will tell you which one is affected by the resistor you have set.
From the measured value, you should set it 50-150 ohms less and later reduce the value in 20-40 ohm steps until it is perfect (fast content scanning and track switching, noiseless (no beeping) operation).
ponsi
ponsi picture
Saludos los dos se jiran a la derecha. Pero con tester digital. En la escala de 3.000 hmios. El vídeo entre estremos debería marcar. 1.500 o1.600. y el ponsetriometro de audio 680 1.000.
