Hello, my amplifier Teac AG-V3020 has power problem, most of the time I’m not able to power it on, even if sometimes it goes ON. Any idea about the reason? Add new comment Comments 2020, December 8 - 06:19 #455285 zsugori 15 years 6 months**** ? V 0 2020, December 7 - 18:29 #455281 Kari 14 years 7 months***** Hi, Do you have SM? https://elektrotanya.com/teac_ag_v3020.pdf/download.html 0 2020, December 7 - 22:17 [Kari: #455281] #455310 Clay Visitor Yes, but is not easy to detect which elements are involved switching from stand-by status to power-on status 0 2021, January 29 - 18:01 [Clay: #455310] #460964 Clay Visitor Problem solved. Transistor Q901 in front PCB (so hard to reach) was defective, its HFE value was one third of nominal. Now everything is working good. 2 2025, April 29 - 21:24 [Clay: #460964] #566221 Kim Visitor I'm having the same issue. I am having a hard time locating a replacement pnp transistor to replace the original. (Q901) 0
V
Hi,
Do you have SM?
