BROTHER MFC-9700-9760-9800-9860-9880-DCP1400 MULTIFUNCTION-CENTER 2001 SM
PRINTER - SERVICE MANUAL
50.2 MB
PRINTER
Looking for similar brother manual?
BROTHER MFC-9700-9760-9800-9860-9880-DCP1400 MULTIFUNCTION-CENTER 2001 SM service manual (1st page)
Preview of BROTHER MFC-9700-9760-9800-9860-9880-DCP1400 MULTIFUNCTION-CENTER 2001 SM [1st page]
BROTHER MFC-9700-9760-9800-9860-9880-DCP1400 MULTIFUNCTION-CENTER 2001 SM service manual (2nd page)
Preview of BROTHER MFC-9700-9760-9800-9860-9880-DCP1400 MULTIFUNCTION-CENTER 2001 SM [2nd page]
    BROTHER 2001 MFC DCP 1400 9700 9760 9800 9860 9880 DCP1400 CENTER
Relevant PRINTER forum topics:
Laserprinter Brother DCP-L2530 no power - Power Supply?
Hello
my printer have a problem with the power supply and only measure 6V instead of 24V.
My printer is a Brother DCP-L2530DW
It won't switch on
I've already checked most of the components on the power supply
No short circuit
Fuses - ok
PTC/NTC - ok
Thermal fuse - ok
MOSFET - ok
Optocoupler - ok
Electrolytic capacitors - ok
C10 and c11 - ok (100pF and 470pf / 1000V)
Primär - OK - 320V DC -OK
Unfortunately I don't have a datasheet of the IC MIP0050 and can't make any measurements - ramp voltage, supply voltage etc.
I would be very grateful for tips
Brother MFC-L 8690 futohenger beszerzese
Sziasztok. Kerdesemet foleg /de nemcsak/ a Brother nyomtatokat javitoknak teszem fel. Irto kinos es szoros helyzetben vagyunk, Van egy uj kliensunk, egy nagy allami intezmeny, ahol az igazgatosag titkarsagan levo szines Brother multifunkcios nyomtato kemencejeben a futohenger tacsra ment. Egyik itteni beszallitonktol azt az infot kaptuk, hagy a HL5240 futohengere talal bele. Es van is raktaron. Nagy orom, kuldtuk is az arajanlatot a kliensnek, el is hoztuk a gepet, de sajnos nem talal az uj futohenger. Az eredetinek a vegei kissebb atmerojuek, es a fogaskerek erre van meretezve. A kerdes a kovetkezo lenne: tud valaki egy olyan modellt, amelyiknek a futohengere a vegein kissebb atmeroju? Talan a kepek beszedesebbek lesznek.
https://www.aliexpress.com/item/4001095565737.html     ilyen az eredeti.Ha valakinek lenne netalan, irjon. Koszonom.
imprimente Brother MFC-J6930DW ne s'allume plus
quelqu'un a déjà démonté une imprimante brother de se type pour vérifier la carte d'alimentation ou dispose du manuel de service
merci
Brother DCP-357C nyotatófej kiszerelése és tisztítása
Kaptam egy Brother DCP-357C kombinált nyomtatót. A szkenner működik, a fej viszont beszáradt állapotban volt (a nyomtó részt már évek óta nem használták). A nyomtatófej alá ioncserélt vizes kéztörtlő papírt téve, sokadszori próbálkozásra a szines fejek beindultak, de a fekete nem. Szeretném kiszerelni a fejet egy alaposabb (közvetlen oldószeres) tisztításhoz, de kéne hozzá a szervízkönyv. Ha valaki tud DCP-350C, DCP-353C vagy DCP-357C szervízkönyv elérhetőséget, nagyon megköszönném, ha segítene. Van egy kerregő hang (ez a próbálkozások közt jött elő) amikor a nyomtatófej a bal szélső helyzetbe mozdul. Oda is szeretnék "bejutni", megnézni, hogy mi okozhatja. Szervízkönyv nélkül nem akarok kísérletezni. Üdv. Gábor
