There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Sziastok!
Van egy Computherm q7RF thermostatom, de nem egészen úgy viselkedik, ahogy kellene. A vevőben elfáradt egy 330nF 275V X2 kondi a tápban, csere után feléledt. Az összes elkót is cseréltem, de még mindig furán viselkedik.
Az adót nem látja a vevő.
Erre írja a leírás, hogy a vevőn 10sec időtartamra az M/A gombócot nyomva kell tartani, amíg a LED zölden nem villog, majd az adón a SET, és DAY gombot 10sec időtartamra nyomva tartva új azonosítót generál, és párosodnak..
Nos, nálam ha a vevőnek tápot adok, a zöld villog magától. Ha röviden megnyomom az M/A gombot, a LED nem villog, világít. 10sec nyomvatartás mellett nem történik semmi, a relét manuálisan ki tudom vezérelni, ekkor a piros LED világít.
Olyan, mint ha a leírás, ami mindenhol megtalálható, és "új software" feliratú, az nem lenne ehhez jó, vagy valami még szivat..
Ismeri valaki ezt a szerkezetet? 2007-ben szögeltem fel a falra...
http://www.quantrax.hu/userfiles/file/hu/Q7RF_hu.pdf
Udvozlet mindenkinek. Ket kulonallo kabel szolgaltato adasat szeretnem egy TV keszulekbe kulon kulon hasznalni.Ugy gondoltam hogy jo lenne valami atkapcsoloval atkapcsolni hogy ne keljen ki be dugdosni a csatlakozokat. Ugy ahogy a tobb LNB-s muholdvevo nel a diseq mukodik. Csak szeretnem tudni hogy hogy vezerlodik ,milyen inpulzusokkal lehet megnyitani a DISEq bemeneteket?
Minap telepítettem egy digitális műholdvevőt. A készüléket hibásan vettem, a fejtáp kapcsoló IC halt meg benne, és mivel beszerezhetetlen volt, építettem egyet. Utánaolvastam a feszültségeknek:
Feszültség terjedelem vízszintes polarizálás 11,5 - 14V
Feszültség terjedelem függőleges polarizálás 16 - 19V
Én 13 és 18V-ra lőttem be, itthon kipróbáltam, működött, 22kHz-es átkapcsolás is hibátlanul ment.
Kimentem a helyszínre, és az ottani működő, de hibás készüléket cseréltem (távirányítóra nem reagált időnként), és feltettem egy nagyobb tányért, hogy a Duna TV-t lehessen fogni, az LNB maradt. Satfinderrel beállítottam, tökéletes kép, jó vételi szint, hurrá. Satfindert kiveszem, itt jött a meglepetés, jöttek is a csatornák, amiket itthon beprogramoztam, de a Duna az nem. Értetlenül álltam a dolog előtt. Visszaraktam a Satfindert, jó. Kivettem, nem jó. Visszaraktam a régi beltérit, azzal jött hibátlanul, tehát az antenna jó volt. Akkor tűnt fel, hogy a Vertikális adások nem jönnek csak. A másik beltérin kb 0,2V-al kisebb volt a feszültség, de hát mondom, az nem létezik, hogy ennyit számítana. A vége az lett, hogy begbontottam az árnyékoló harisnyát, és egy 10 Ohmos ellenállást sorbakötöttem a fejjel. Vételi minőség nem romlott, így számomra megoldódott a probléma. Ha közelebb lett volna a telepítés hely, persze a feszültséget vettem volna lejjebb, de helyszínen ez volt a legcélravezetőbb.
Üdv: Jácint
