There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
DIZÁJN MARAD , EGY BLUETOOTH modul lesz beleépítve....
Egy régi wurlitzer CD olvasóját kellene feltámasztanom.
Sajnos beazonosítani nem tudom, valami grundig CD lejátszóban is hasonló lehet.
Panelen P/N 541-Z10A-21CV-EV és 280-521462-010 jelöléseket találtam.
Gyakorlatilag egy külön egységet képez, 8V táp kell neki, kijön az L,R hangkimenet. Fedelet lehajtva indul a beolvasás. Kezelőgombok is ezen az egységen vannak. Pár képet csináltam.
Cseréltem lézer pick-up-t (hallani , hogy fókuszál , meg a lézer is indul) de sajnos nem indítja a lemez forgatást.
Panelen lévő IC-k CXA2542Q, CXD2593BR , KA9258D
PICK UP: KSS-213C
esetleg a komplett CD elektronikát keresem. (vagy valami "belehekkelhetőt")
Köszi a segítséget
Szabi
Üdv Mindenkinek!
Sajnos, a LIDL-ben is kapható, vezeték nélküli indukciós elven alapuló töltővel ellátott, több funkciós, Li-Ion akkumulátorral működő LED lámpám, az akkumulátor tönkremenetele miatt működésképtelenné vált.
Magával rántotta a töltőjét is, amelynek a típusa WTG 001 AHG, aminek a rajza elérhető a neten is. Ha esetleg más is találkozott vele a C4 pozíciószámú kondenzátor 220 nF és nem 2,2 nF mint a rajzon.
A lámpa rajzát viszont sehol nem lelem. Ez sem lenne nagy probléma, viszont az alkatrészek kimérése alkalmával találkoztam egy 8 lábú IC3 pozíciószámú SMD alkatrésszel, amit jelölés hiányában azonosítani nem tudok, de feltehetően a fő problémát, annak meghibásodása okozza.
Tehát, ha valaki rendelkezik az eszköz rajzával és hozzáférhetővé tenné, megköszönném. De, ha "csak" a jelzett alkatrész típusát közölné, azzal is sokat segítene.
A 14430 tip. Li-Ion akku helyett, már sikerült egy 14500 típus beleapplikálni a védőáramkörrel együtt..
Köszönettel!
A fenti hegesztő semmit nem csinált. Első körben az eddigi halott alkatrészek: IGBT-k, 15V-os zénerek, VIPER20, ellenállások. Megjött a 300V, a kijelző, elindult a ventillátor. Jelzi, hogy mekkora árammal kell(ene) dolgoznia. Azonban még nem hegeszt, és állandóan világít a "túlmelegedés" ledje. Volna valakinek további ötlete, estleg rajza? Az IGBT-ket vezérlő vendégpanelen is volt egy 10V-os halott zéner, gyanítom, hogy az ott lévő IC is halott lehet, ami viszont nem olvasható, nem látszik rajta a felirat.
Köszönettel:
Szerinted ez egy jó cím??
Kalex
Azért így már jobb! Nem?
